stealer won't give copy of sert map
RE: stealer won't give copy of sert map
That really stinks. [:@] Living in Florida, I would be heading up to see Doc for a tune.
I've got a buddy with a 07 SG with the HD 110 kit installed by the local dealer, and it gets a whopping 90 HP on the dyno. [:@] So I also know where not to go for a tune.
ORIGINAL: connsmith
It is how they make money. I put software on your computer, I will not teach you how to replace me...
Example: If you bought 3 quarts of oil at a dealer oil change and then the dealer put a lock on your oil fill cap and kept your 1/2 quart of leftover oil and told you that you would have to come back to them to have it topped off would you tolerate that?
ORIGINAL: KBFXDLI
I don't know about that since Bill Gates has made quite a few bucks by giving you the disk when you buy a computer with his software on it. Can you imagine how Microsoft would have screwed up if they took the same approach? Gate's theory is to keep making it better so you come back for more-better. HD might learn something there. IMO
ORIGINAL: geargrinder
I can see both sides but anotherargument forhaving the file is, suppose your ECM gets fried you moved orthe dealer lost file or went out of business, you have to start from scratch again with a retune if you don't have file.
I had the same thing happen but I called the tech that did the dyno and told him I
wanted a copy just incase the ecm failed, after a long discussion he agreed if I
brought in a usb drive for him to put it on.
It is in your ecm, not in your SERT connector, you paid for it...you should have it,
just in case...
just in case...
lt1tyrell
10-24-2010 04:20 PM
