no fuel pump on 2007 fxd
(THIS IS ALSO POSTED IN THE DYNA FORUM)
Hi all
I have a problem which I think I caused but I don't know how to fix
I pulled some parts off to have chromed before Easter, including the black wrinkled painted speedo mount on the handle bars and the heald light.
I was also going to pull the tank to, but didn't get time, but I emptied the fuel line by starting the bike and pulling the fuel pump fuse and let the bike die.
nothing else electrical was touched. I did how ever turned the ignition on while putting the headlight on, the speedo was still off ( I THINK THIS IS THE MISTAKE )
So today after thinking everything was ok, I wheeled the bike out to take for a shake down ride, but when attempting to start, I have no fuel pump.
The battery is ok, it will crank the bike, I have checked the fuses with a multi meter, same all ok.
So I have looked at the dtc codes, this is what I found
P has PO261 (Front injector open/high)
and P0263 ( Rear injector open/high)
S has U1016 ( loss of all ECM serial data at TSSM )
SP has U1016 (loss of all ECM serial data at speedo)
T has no rsp (not connected)
I have cleared the all the codes then turned the ignition off then back on, the SP codes has stayed cleared, but the codes for P, AND S have come back.
I think I should have disabled the alarm system before removing the speedo, it looks like the security system has cut the fuel pump
Does anyone know how I am to reset and fix this problem
Thank you
Peter
Hi all
Thank you
Peter
RE: no fuel pump on 2007 fxd
I have finally got it going today
I rechecked all my fuses with a multi again, still ok, but when I hold the fuses from the ECM up to the light, it dosen't look right in the middle.
So I swapped it with a new one, the bike started.
so even with the multi saying it has a connection, it look like a dicky fuse has caused all this fuss
Thanks anyway
Peter
Thanks anyway
Peter
Andrew Tischer
04-18-2019 07:00 AM
Batbuds
05-12-2008 11:57 AM
