Electrical Snafu 08 FLHRSE4
Just finished installing lighting upgrades - HD passing lamp kit with lowered turnsignal housings, changed front and rear turn signal bulbs with Kuriakyn LEDs, installed a Badlands Illuminator run/turn/brake controller and LED license plate frame with turn signals, and as far as I can tell, everything is in the proper place as per instructions ie: load equalizers upstream from the controller.
WhenI hooked the battery back up, the tachometer and odometer lights start flickering with the ignition switch in the OFF position and go out when switched to ON. Badlands included the procedure for re-programing the OEM module but I can't get to that untill this problem is solved.
Can anyone steer me in the right direction on this? I'm not sure how to approach this.
Lancemchn
2014-2023 Touring Models
12-20-2019 12:36 PM
