Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Has anyone out there ever had to replace the ignition switch on 2002 softail. Mine has a slite short when you jiggle it. What I need to know is, when you change it how can you keep your original key. I would like to because of the fork lock.
Thanks you guys, Turns out that I dissasembled the switch ,cleaned it, sanded it with scotch brite,regreased it and reassembled it, now its fine. Didn't know it was so easy to disasemble one.
