Does the Fuel Pak and Arlen Ness Big shot eliminate the 02 sensor signal?
RE: Does the Fuel Pak and Arlen Ness Big shot eliminate the 02 sensor signal?
ORIGINAL: RBFB
That is the question, I know the PC3 does, I was thinking about trying one of these and see how it goes, I don't want to eliminate the 02 feedback though.
Frank From D>B>W
I have the fuel pak and it is designed to work with your exhaust & high flow a/c to adjust the fuel flow to make the bike run correctly when you add the lower restrition exhaust and flow more air with the a/c.
IHAVE FUELPAK & ARLENESS BIG SUCKER ON MY 2008 SOFTAIL STD THE 02 SENSORS ARE PART OF THE FP SYSTEM BUT PERSONALY I WOULDNT BUY AMOTHER FP AS V&h DOES NOT SUPPLY DETAILED TUNING INFORMATION LIKE THUNDERMAX OR POWERCOMMANDER DO .THIS MEANS ITS ALL MOST IMPOSSIBLE TO DYNO YOUR BIKE UNLESS YOU DISCONNECT YOUR 02 SENSORS GOOD LUCK WITH WHATEVER YOU CHOOSE
