SERT map?
Old 03-16-2008 | 11:34 AM
Bamboo's Avatar
Bamboo
Default SERT map?
What base map should I use for 08 Fat Bob with stage one big sucker and big raduis 2into1 exhaust. Looking for a good place to start. I do have the old SERT.
Old 03-16-2008 | 12:20 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Default RE: SERT map?
[align=left]Calibration # 67: 2007 - 2008 'All Market' Shotgun / Shorty Dual Exhaust with O2 Sensors[/align][align=left]Configuration: 1580 SE A/C & Race Exhaust[/align][align=left]File Name: 176AE104-A0.MT6[/align][align=left]Components:[/align][align=left]• 25deg Injectors P/N 27709-06[/align][align=left]• SE Air Cleaner and Breather Kit P/N 29440-99C[/align][align=left]• Race Exhaust[/align][align=left][/align][align=left]This seems to be the closest map off the V477 SERT file since all the 2 into 1 exhaust maps have other engine modifications listed on the map definition. Do you have the V477 software?[/align][align=left][/align][align=left]If you need V477 get it here: http://www.sendspace.com/file/q7d973[/align]
Old 03-16-2008 | 01:19 PM
Bamboo's Avatar
Bamboo
I do have the v477 software. I was thinking of this map too but was unsure of the injectors?
Thanks for the reply!
Old 03-16-2008 | 03:46 PM
KBFXDLI's Avatar
KBFXDLI
You will probably want to get your bike dyno tuned since you have the 2 into 1 exhaust and there isnt a map close to that configuration. You might consider checking with Latus Harley Davidson and see if they have a dyno map for your setup that they would sell you. Their tuning specialist is Mike Stegman and if you logon to the "ask Mike" forum and tell him what you have he will let you know. They are located here: http://www.latus-harley-davidson.com...sword=assigned
Old 03-16-2008 | 03:51 PM
KBFXDLI's Avatar
KBFXDLI
ORIGINAL: Bamboo
You should have those injectors but if you want to be certain. Take a flashlight and look on the left side of the bike under the gas tank behind the horn and you can read the injector part number. It should match the number on that map. If it doesn't match then check with your dealer or the Moco to see if it is a 25 degree injector. It may even have 25DEG printed on it.
mark1234
04-30-2008 09:38 AM
SMacDunk
02-23-2008 06:57 PM
jimclaypool
10-12-2007 11:08 PM
Uncle_Timmy
07-13-2007 11:45 PM
07deluxe
02-13-2007 04:17 PM
Quick Reply: SERT map?
