SERT Difficulties
Old 03-14-2008 | 02:02 PM
fireman403's Avatar
fireman403
Default SERT Difficulties
Ok, has anyone encountered difficulties trying to establish computer-to-bike communications recently? I just tryed to connect my new SERT and I keep getting the message "ALDL adaptor was not responding" and it tells me tocheck the connections and so forth. I've done all of that to no avail. I did continuity checks with an ohm meter on the cables; all good. I did a search here on the forum and have tried all of those applicable suggestions too like re-loading the Belkin USB adapter, reloading the SERT programs, restarting the computer several times, tried 2 different computers one with a normal serial port, used both Windows Vista and XP operating systems, tried a downloaded copy of SERT version 4.7.7; still no luck.
I was moments away from bashing the SERT adapter with a hammer, but then I remembered all this stuff has cost me some $400 so far. I thought about removing the fuse from the bike's ECM to 'reset' (kinda like with a car ECM), but wasn't sure that would work. My next stop will be to have it checked out by a dealer.
Any other thoughts would be appreciated. By the way, the bike is a 2006 Electra Glide Classic and the SERT adapter came withversion 4.6.2.
Thanks.
Old 03-14-2008 | 02:37 PM
Doc 1's Avatar
Doc 1
Default RE: SERT Difficulties
Ignition on, stop switch to run, pick a comport.
Old 03-14-2008 | 03:33 PM
Bertk's Avatar
Bertk
If you haven't already, download and install the latest driver for the Belkin USB Serial Adapter.
Old 03-14-2008 | 04:35 PM
Steve Cole's Avatar
Steve Cole
HD EFI Guru
Take a step back and look at what Doc and Bertkhave said if that doesn't solve it try the updated drivers from Belkin. Were all here to help if we can.
Old 03-14-2008 | 08:02 PM
fireman403's Avatar
fireman403
I should have mentioned that I have tried all those things too (ignition AND run switch in ON, selected the COM port, downloaded the latest drivers from the Belkin website at least twice); still the same "ALDL adaptor was not responding" message.
By the way; is 'ALDL' referring to the SERT adapter or to the plug on the bike.
Old 03-14-2008 | 08:54 PM
Steve Cole's Avatar
Steve Cole
HD EFI Guru
Yes, thats what we call the electronic box. It sounds like there may not be power at the test connector or the USB adapter is not working properly for our application. Do you have a friend or neighbor that might let you borrow a computer that has a serial port?
Old 03-14-2008 | 11:08 PM
fireman403's Avatar
fireman403
I guess I should have also mentioned that I had trucked my desktop computer out to the garage to try itsserial port. You guessed it; same silly message.
Hmmm... Let me guess; most Harley dealers aren't too receptive to exchanging a SERT ??!!
Old 03-14-2008 | 11:51 PM
Doc 1's Avatar
Doc 1
You don't by chance have the carb Race Tuner wire set do you......I believe the conector is wired a little different than the SERT connectior
Old 03-15-2008 | 12:11 AM
deadwood1783's Avatar
deadwood1783
I have seen this issue with both usb and serial port computers using everything from Windows 2000 to XP and Vista. It is usually an operator error. Com port doesn't auto connect, software did not load correctly, etc. Try this, remove the SERT software and reinstall. Reboot your computer and hook up all cables starting with the data port on the bike and work your way out to (hopefully) a 9 pin port computer. Turn on run button and ign switch, select com port and get ECM info. Many times I have also seen after you do get com and try to load a tune it will drop off line at 25% and tell you it is unable to load bootloader. The # of computer configurations and baud rates is the likely culprit. The SERT is a fine tool but has always been quirky. Good luck!
Old 03-15-2008 | 08:35 PM
littlet's Avatar
littlet
Have you looked at the data port plug? Make sure none of the pins arebacked out of the connector,or any wires are broken. That would cause the race tuner not to communicate with the computer.
Quick Reply: SERT Difficulties
