Throttle "sticking"
Old 03-13-2008, 05:16 PM
SenecaBlues's Avatar
SenecaBlues
SenecaBlues is offline
Default Throttle "sticking"
My '08 UC has about 400 mile on it, and today it started to over-throttle at idle. I can push the throttle forward manually about a quarter of an inch and it revs down to normal "potatoe" idle but when i release it it snaps back to the higher (about 2k) revs. I don't see an obvious adjustment.
Any ideas?
Thanx
Old 03-13-2008, 06:06 PM
Skivvy9r's Avatar
Skivvy9r
Skivvy9r is offline
Default RE: Throttle "sticking"
Call the dealer and let 'em know you're bringing it in.
Old 03-13-2008, 06:08 PM
VTwinJaxFL's Avatar
VTwinJaxFL
VTwinJaxFL is offline
It's an 08, electronic throttle, under warranty......
Old 03-13-2008, 06:25 PM
SenecaBlues
Got it. Will do. Thanx
Old 03-13-2008, 11:35 PM
Bertk's Avatar
Bertk
Bertk is offline
Sounds like a warranty issue to me.
Old 03-14-2008, 11:07 AM
smokin's Avatar
smokin
smokin is offline
this would be a great time to have the Chrome "throttle by wire" Wires put on!
No, you can't see them, but you'll know they are there!
Old 03-14-2008, 06:50 PM
Aggie's Avatar
Aggie
Aggie is offline
Try cycling the power 4 times...with your hand off the throttle. Sounds like the twist grip has learned a bad zero position. Cycling themain switch 4 times with the run/stop switch in the run position will allow the ECM to learn a proper zero.
Always make sure your hand is off the grip when you turn the bike off...this is when it records the zero position voltage.
Old 03-15-2008, 06:50 PM
SenecaBlues
Thanks for the tip. I'll give it a try.
Old 03-15-2008, 08:02 PM
SenecaBlues
Aggie, You're the best! Saved me an hour ride to the dealer.
Wait! I was going to take a day off from work and ride... [sm=biker.gif]
Aggie, You're not as great as I thought!
But seriously, thanks again!
Old 03-17-2008, 02:34 PM
barrygreen's Avatar
barrygreen
barrygreen is offline
My 08 SG has done that a couple of times and your correct
to cycle the switch with your hands off the throttle to let it
relern the 0 position.
Quick Reply: Throttle "sticking"
