Brake light wont turn off
RE: Brake light wont turn off
Take your foot off the brake........no? Check the pressure switch for you foot brake (unhook the wire).. If not that then the little switch on the front brake assy is not opening. You'll have to adjust the control positioning or replace the switch. Don't forget to put a piece of cardboard bertween the lever and the housing before removal/installation (that is in the Manual).
