SERT Map for Rineharts
I thought I had seen a post with the answer I needed, but I can't seem to find it again, so I have to aska question (yes, I used the 'search' feature).
Ihave a 2006 Electra Glide Classic that is stock except for a Screamin Eagle air cleaner kitand (it will soon have)a Rinehart Dual Exhaust system. I also have a SERT (version 4.7.7) coming hopefully sometime this week.
Can anyone recommend a good starting SERT map to use with the setup above? I'm going to do all of this work myself and no, I don't really plan toput on a dyno.
Thanks for the help.
RE: SERT Map for Rineharts
I have the same type of set-up, but on a 07, and I started with the map for a Dyna with dual exhaust, the map for touring bikes is designed with a crossover. You may have to tweak it some for your bike. My 07 and your 06 will be way differant due to the o2 sensors.
