Sparkplug choice
Sparkplug choice
I was reading in the DIY forums regarding alternatives to the HD stock plugs. One of the things mentioned there is the potential for ION sensing to be affected if not using HD plugs. I'm somewhat ignorant in this area.
Basic plug construction is a constant throughout the industry, with the noted exception for the differences used in fabrication for heat ranges/ceramics and electrodes. It's not like there is a sensing chip in the HD plugs or anything simialr to that. That being understood, if the non HD plug heat range is matched, what is so special about stock HD plugs that by changing to another brand would affect ION sensing as mentioned by HDF Tech in the DIY forum?
RE: Sparkplug choice
Your scoot will run on the other plugs, but the ignition system was designed with the champion plugs and stock wires. I may be wrong on this as I am not a mechanic, but the ion knock sensing system works on electrical signals recieved thru the plug wires from the plugs. Changingthe wires or plugs may change the signal slightly and may cause your knock to be incorrectly diagnosed by the equipment or not sensed at all.
You will get a multitude of different answers to this question. If you want to test another plug by all means give it a try. If your happy with the results stick with it.
Chris
Chris
Well the best is yet to come.
This spring you'll be able to buy HD gasoline, its been specially blended for the unique demands of the Harley V-Twin engine. Caution: Use of other brands of gasoline MAY void your waranty. MSRP: $9.99/gallon.
And later this summerproprietary tire inflation blendswill beavailable;one blend is specific totouring and softail models,the otheris forsport bikes, dyna, sportster and V Rods. MSRP: $1.99/psi.
ORIGINAL: fxrp
ORIGINAL: CCPD
Chris
Chris
ORIGINAL: KBFXDLI
I tried some autolites......threw codes every time I rode it. So there is some truth to the ion sensing issue. BTW, I tried the Harley Davidson air in my tires.......works great!!
