Stock ECM calibration 2008 SERK-same as SERT calibration?
Do the stock ECM's on the CVO bike's, in particular my 2008 SERK, come with a different ECM calibration than what one would download from a canned SERT map? In other words, here's the calibration I would probably load from the Super SERT I just received:
Calibration # 104: 2008 Touring Exhaust with O2
Sensors
Configuration: 1800 SE A/C & Race Exhaust
File Name: 200UI001
Components:
• SE Air Cleaner and Breather Kit P/N 29440-99C
• Race Exhaust
I already have the stock Touring exhaust and would just need to add the SE Air Cleaner to use this map. Is this correct OR
Is this or a similar performance map already loaded on my 2008 SERK or is the stock map generic and the same as whats loaded on all 2008 Touring bikes?
Sensors
File Name: 200UI001
Components:
• Race Exhaust
RE: Stock ECM calibration 2008 SERK-same as SERT calibration?
The Stock ECM calibration is EPA compliant, the EFI Super Tuner calibration is a RACE/Off Road Competition Use Only..... As are ALL SERT/Super Tuner cals....
They are COMPLETELY different...
You can install that selected map (104) with the SEAC, and you will be fine without a tune...
ORIGINAL: Shovelhead Bob
maxum96
04-27-2008 11:05 PM
brewdog
13
04-18-2008 04:40 AM
Ace07FXDL
03-22-2008 12:17 PM
