T-Max & dead battery
RE: T-Max & dead battery
ORIGINAL: intruder
Thanks I'll try updating the firm ware I haven't done that yet. I'm also going to contact T-Max tomorrow.
Ron
I found this in the tuning manual, but I may not have the latest manual downloaded.
Low fuel light (Up to 2007 models)-
The low fuel light will operate exactly the same
whether you are using the ThunderMax ECM or the factory ECM. Our in house
testing has found that the low fuel light does not activate at the same time on every
tank. What this means is that the volume of fuel left in the tank when the low fuel
light comes on, varies almost every time it is activated. This inconsistency is not
ORIGINAL: rbabos
From what the site says the light always worked but when it came on was not always accurate, or predictable.Recommendation was to use the odometer until it was resolved, which most of us do anyway.4.6 is the fix.
Ron
Ron
