too many lights???????
ok guys.....can you tell me if i have to upgrade any electrical if i hook up the two smaller headlights on the side of the main headlight and also a set of foglights on my crashbar???? Would that be too much for the stock electrical or would i have to upgrade.....and what would i hook those lights up too???? If anyone can help me i would appreciate it very much!!!!!
RE: too many lights???????
I have the foglights on my crashbar, together with the normal passing lamps. Never had any troubles. I have an FLHT so there was a spare switch hole in the console. I added a second ACC switch to control them. As Sooee said, a relay is a good idea. Power the lights from the battery through a fuse, then the relay. The switch only powers the relay.
bear68
Electrical/Lighting/Alarm
04-03-2010 06:17 PM
