looking for a Map PCIII usb
anybody have a map thats close to what i may need i down loaded a canned map from Dynojet
im running
2005 FLHTPI
stock 88"
Rienheart True duals
Ness big Sucker
Harley stage 1 flash (crap) but gave me the rev limiter
Andrews 37b Cams
closest i found was the 95" kit with se203 cams se air but this is running me pig rich getting close to fouling plugs
if anybody has a map that may get me close for now im getting ready to do a 95" kit with heads in a couple weeks so just need a map that i can run for now after the 95 build ill be getting her on a dyno
thanks in advance
G
im running
2005 FLHTPI
stock 88"
Ness big Sucker
Andrews 37b Cams
thanks in advance
G
RE: looking for a Map PCIII usb
05FLHTPI, I would try the 807-125 map on dynojets website. It's under the stageI maps. It's for the Reinharts with SE air filter and stageI flash. Doesn't show the cams, but should get you close enough to get by until the 95" job.
The map for the 95" kit will put more fuel to compensate for the larger displacement.
