Adding A Tach
Old 07-16-2008, 03:53 PM
Malibyte's Avatar
Malibyte
Malibyte is offline
Default RE: Adding A Tach
Murph: The link still works, and I've printed it out. Thanks VERY much for the info! This should be relatively painless.
Bob
ORIGINAL: murphdog
Malibyte, the 03 Dynas still had the pink tach signal wire under the dash. It's bundled up in the wire harness under there, it was easy to find on mine...the pink wire goes to the yellow tach wire. \\\\\\;You can also get +12 volts and ground under the dash. If I remember right, the orange/white wire is +12 and goes to the red tach wire. Black is ground and goes to the \\\\\\;black tach wire.
Here's the mini tach instruction sheet, although the link probably won't work. http://www.box.net/shared/tzgvfzf4so
Old 07-16-2008, 03:57 PM
Malibyte's Avatar
Malibyte
Malibyte is offline
Whittlebeast: I wanted to stick with the Harley tach, but if I hadn't done that, this thing looks pretty decent. I may put one of these on my other bike.
Thanks
Bob
ORIGINAL: whittlebeast
http://www.tinytach.com/tinytach/commercial.php \\\\\\;
Old 07-16-2008, 07:39 PM
Old Gunny's Avatar
Old Gunny
Old Gunny is offline
I put a Barrons tact on my 2008 Fatboy. Works perfect. I did have to source the ECM #3 slot for the signal. If you are not somewhat able to do this kind of thing, I would suggers the HD versions.
This&nbsp\\;kind of stuff can&nbsp\\;make me very nervious. I'm old now so I figure I'll just pleat Alshimers to the HD Tech if I break something and have to ask for help. Kinda look helpless. and poor.
Old 07-26-2008, 11:17 PM
Malibyte's Avatar
Malibyte
Malibyte is offline
Murphdog: Tach is installed and works fine. The job took me about an hour and was completely painless. You're right, orange/white is hot and pink is the tach signal. I had to run a ground to the chassis, though...black wire at the dash plug was not a ground.
Anyway, just wanted to give you a shout out with thanks.
Ride safe -
Bob
Old 07-27-2008, 12:00 PM
murphdog's Avatar
murphdog
murphdog is offline
Glad you got it Malibyte. Sorry about the black wire, don't have my 03 manual anymore.&nbsp\\;I kind of remember&nbsp\\;there&nbsp\\;is more than one black wire under there and it had to be the one on speedometer terminal 7,&nbsp\\;there's another black wire that goes to the odometer reset button. It's still that way&nbsp\\;on the 07.
BFC883
Welcome Area Only
20
05-22-2018 07:31 PM
Mauitim
Welcome Area Only
19
05-02-2018 07:06 PM
harleyheaven
Softail Parts
19
01-04-2010 11:53 AM
harleyheaven
Touring Parts
12-28-2009 07:08 PM
cj_slowdown
Shovelhead
01-17-2007 08:10 PM
Quick Reply: Adding A Tach
