hard start after PCIII rt
Havn trouble gettn my 06 Dyna to start after puttn in pcIII, slip on trumpets no baffles, and S1 big sucker. Also have a really bad decel pop in third and second gear. Im runnin map M811-004 .....any clues? Also the check engine light comes on after starting for a few seconds then goes back off (not much concern just curious..maybe the stock ecm temporarily thinks 02 sensor prob)
RE: hard start after PCIII rt
I've heard you want to hit the run button, listen for the fuel pump priming, and hit start before the priming stops. My '06 Fat Boy starts normally but I have heard of hard starts and that's how folks were dealing with them. As far as the popping, does your map account for you not having baffles?
ORIGINAL: tom134
True whittlebeast - I think thePC is the cause for the hard starts. The popping may be caused by a map that doesn't account for the removal of the baffles.
Gentleman, I thank you for the guidance i will be sure to try it. The map is designed for baffle removal with V&H pipes, I have bell tips. Today was colder than normal and the bike stumbled a bit between shifts until it was warm....is this also a known problem or am i runnin rich?
08 Nightrain
09-19-2010 06:35 PM
speed8988
11-07-2007 08:05 PM
