PC III 08 Sportster problem
RE: PC III 08 Sportster problem
I don't remember what code was set on mine, but it was not what you have. I had some relay code set. Does the light go out when the pc III is NOThooked up? If so, as already stated, get new pc. May want to check to make sure you didn't bend any pins over in connectors.
 \\;Turn on, engine lamp goes out after 4 seconds and comes back on and stays on, it tripped a diognostic trouble code, meaning the ECM(BRAIN) is not getting a sufficient reading from something that the PCIII bypassed. If it runs good, situation normal. Recomend EFI Race tuner from Harley, it was manufactured to communicate with stock equipment and will tune to any engine configuration you would want to do, but I understand, the sticker shock could cause downsizing to a studio apartment.
howitzer88
03-28-2011 07:33 PM
