Power Commander III and EFI question
I finally got my PCIII installed on my 08 FLSTC Anniv. Edition and had a question. I am assuming the 08 EFI takes the data it receives from the o2 sensors and makes minor adjustments to the air/fuel mixture. When the PCIII is insis issue with the O2 sensors?talled the O2 eliminators are put on. So now if there is a change in temp/humidity/altitude the EFI is unaware of changes that need to be done. How does this affect the bike and its performance? I am also assuming that if the SERT is used the O2 sensors are left on. If so then it would appear that maybe the SERT was the way to go. Did I mess up getting the PCIII because of the O2 sensors?
RE: Power Commander III and EFI question
I would think not... as long as you had the bike remapped for the 1st set of V&H pipes. As long as you do not have any popping or cracking sounds right now, I would think you are good to go. I just installed BCT's Thunder Monster baffles in my V&H Bigshot Longs, and I seem to be fine. I did not have to remap or anything. I plan on getting a PCIII in the NEAR future, and will probably check the map, just in case.
ORIGINAL: gdaustin
What it won't do is compensate for changes, like exhaust, intake, cams, etc. For that you'll need a remap, but once a good map is established you can ride it with assurance the A/F will adapt to different altitudes, etc.
Thanks I click I was hoping that was the answer. I can not wait till I can afford theA/C and the pipes. I had my bike dyno'd after the PCIII and the results were 65.9 HP, 80TQ and a flat line for A/F right at the desired mixture according to the dyno guy. Are these good numbers for stock 08 FLSTC except for PCIII? If not what should I shoot for? Thanks.
If you are worried about the O2 sensors, the PCIIIEX works in conjunction with the sensors. \\; You dont have the ability to make as many adjustments as you do with the PCIIusb. \\; They call it the street legal version or California approved. \\; I put on on my bike (mainly because I got it for$175 on e-bay, it seems to work fine with the download I put in it. \\; Think I'm still gonna get it dyno'd though.
ORIGINAL: ricmd
I've \\;had VH Python's \\;and a PC III on my 06 Dyna SG for the past year. I want to install the VH quite baffles (V21869). Can anyone tell me if I will have to remap? \\; \\;
ORIGINAL: electradad
If you are worried about the O2 sensors, the PCIIIEX works in conjunction with the sensors. \\\\\\; You dont have the ability to make as many adjustments as you do with the PCIIusb. \\\\\\; They call it the street legal version or California approved. \\\\\\; I put on on my bike (mainly because I got it for$175 on e-bay, it seems to work fine with the download I put in it. \\\\\\; Think I'm still gonna get it dyno'd though.
I do not think I would even bother and just run a download from Power commander.
