Nightrider O2 IED's - Field Test
Old 04-20-2008 | 03:16 AM
heywood727's Avatar
heywood727
Default RE: Nightrider O2 IED's - Field Test
ORIGINAL: dropone
cruiser85257, I have the IED on my bike now. I like the way they are almost invisible. My question is the extremes as small so you can hide them as well.
With permission from Steve
[IMG]local://upfiles/50578/E564B772CAC14A11AE1F2D5881B60126.jpg[/IMG]
  #912
Old 04-20-2008 | 04:55 AM
RAWHIDE07's Avatar
RAWHIDE07
Anyone know when the xied's will be available to buy?
  #913
Old 04-20-2008 | 07:52 AM
hdrider02's Avatar
hdrider02
Cruiser 85257:
Old style Screamin Eagle II slip-ons (2005), SE air cleaner replaced with K&N and download for air cleaner, otherwise stock.
  #914
Old 04-20-2008 | 08:35 AM
itsmyforte's Avatar
itsmyforte
ORIGINAL: ko4qc
ORIGINAL: itsmyforte
So I built my own for under $10.
What connectors did you use and where did you get them?...I was told the connectors cost about $30....:&gt
I purchased all my parts from mouser electronics except the wire and heat shrink tubing. though you could even buy those there too if you want. I would be happy to list the parts i got if everyone thinks its ok to post it. I don't want to step on any toes.
  #915
Old 04-20-2008 | 08:44 AM
Lone Watie's Avatar
Lone Watie
welcome from me to post the parts/description, and pics if you can.
Watie
ORIGINAL: ko4qc
  #916
Old 04-20-2008 | 10:19 AM
tatt2zzz's Avatar
tatt2zzz
I have on 08 ultra and with the temperature 78 degrees the heat coming off the engine was very hot. This is the first time riding at this temperature. I will buy and install the Nightriders O2 IED device but how difficult is it to install. Cutting wires etc. is not something I want to do.
  #917
Old 04-20-2008 | 11:24 AM
elpoman's Avatar
elpoman
No wire cutting, have to cut some plastic tiesoff the front 02 wires, then unplug the 02 wire and plug the IED's up, then use some plastic ties to secure everything. Do not bend the IED's in the middle, where it is heaver coated, can be bent on end wires. That all there is to it.
  #918
Old 04-20-2008 | 11:48 AM
Lost1's Avatar
Lost1
If you can successfully plug in a lamp cord, you can successfully install IED's.
I did it, and while I'm a fairly decent mechanic, I'm about as electrically challenged as they come... [sm=alcoholic.gif]
  #919
Old 04-20-2008 | 01:49 PM
cruiser85257's Avatar
cruiser85257
HogHeaven:
If your Bike is like mine and all you want is a cooler engine, the XIED's will be sufficient to do the job.
  #920
Old 04-20-2008 | 01:54 PM
cruiser85257
ItsmyForte:
There's information around for how to build them. I don't think it's appropriate to post your recipe in someone elses Kictchen.
Quick Reply: Nightrider O2 IED's - Field Test
