Nightrider O2 IED's - Field Test
Old 04-15-2008 | 04:08 PM
mikeurig's Avatar
mikeurig
Default RE: Nightrider O2 IED's - Field Test
Here's a link to an article that had HD do a remap of some ecm's.
http://www.motorcycle-usa.com/Articl...ID=4022&Page=1
If the bike was built before November.
  #822
Old 04-15-2008 | 05:03 PM
Rider57's Avatar
Rider57
Thanks for posting that tidbit.
I was aware of the bulletin but could not find the actual release from the company.
Steve is working on what may be the fix for those of you stuck with the problems that the 06 Dyna's are having.
More testing is in the works once he narrows it down.
  #823
Old 04-15-2008 | 06:03 PM
mikeurig's Avatar
mikeurig
I'm going to keep my replacement IEDs and let my brother-in-law try them out on his 2007 RoadKing.
Keep us informed of any fixes for us 06 Dyna owners.
I screwed up with retrieving the codes. I didn't have the run/stop switch in the run position.
I only found that out cause I had a check engine light come on today. I had stopped at a store and when I restarted the bike it came on for 4 seconds then went out.
So I double checked the procedure and found that both sensors showed a lean condition and that the rear sensor wasn't responding. I did find that somehow one of the wires in the rear connector came out of the slot.
I cleared the codes and will see what happens in the morning and report back.
  #824
Old 04-16-2008 | 12:24 PM
cruiser85257's Avatar
cruiser85257
Tick, tick, tick, tick....countdown till the EXTREMES hit the Streets.
  #825
Old 04-16-2008 | 01:40 PM
SteveInBC's Avatar
SteveInBC
6th Gear
Can any Canadian riders who purchased the IED tell me whether you got hit for customs duty etc?
Just trying to decide whether to get mailed directly or get mailed to my buddies US address.
Cheers
Steve
2008 FLHTCU
  #826
Old 04-16-2008 | 02:21 PM
BCguy's Avatar
BCguy
Received mine a while back shipped USPS with no additional charges. Have them sent directly to you, fer sure.
Are you going to order the new Extreme version?
  #827
Old 04-16-2008 | 02:46 PM
SteveInBC's Avatar
SteveInBC
6th Gear
ORIGINAL: BCguy
Y'know thats a good question, even $70 needs approval from the CFO/CEO at this time (the bike is still only 1 day old)
Been reading this forum/thread from the beginning and was just ready to pull the trigger when Crusier started gushing about the XIED.
Still checking the Nightrider website but no price or availability as yet.
I was thinking about the IED till the bike was broken-in and then perhaps upgrade to the XIED.
Cheers
Steve
2008 FLHTCU
'Black Pearl'
  #828
Old 04-16-2008 | 03:00 PM
Manfire's Avatar
Manfire
No duty, no taxes to Manitoba.
  #829
Old 04-16-2008 | 03:14 PM
stvmike's Avatar
stvmike
I got mine last week and just got them on. Man what a difference.
The throttle respone in un-real from before and decel popping from just having the slip ons is gone. I can't tell about heat yet it's still cold here.
  #830
Old 04-16-2008 | 03:52 PM
hdrider02's Avatar
hdrider02
I have an '06 fxdbi in which I today rode for the first time with
IED's installed. No codes nor check engine light.
If it had more power, it was insignificant. The bike did have a
slightlylower exhaust tone. What I do no for sure, is the
decel is significantly less. Still some, but no more than my
'02 Heritage had. My bike has the old style screamin eagle II
slip-ons, screamin eagle air box, but at 10,000 miles I replaced
filter with K&N. Also has Harley download. Bike was built in 03/2006.Hopefully, the no throwing codes or check engine light will not occur in future.
John
Quick Reply: Nightrider O2 IED's - Field Test
