Nightrider O2 IED's - Field Test
#461
RE: Nightrider O2 IED's - Field Test
Just another word on Steve's service
I ordered mine last Thursday on 7/3/08 and they showed up today 13/3/08, And I live in Adelaide, South Australia
Outstanding service
Will put them in tomorrow, I just picked up my FXDC today and the IED'S are the first thing going in
Outstanding service
#462
Think I'm gonna have to order a set of these for my 07 RG. Its got Rinehart Slip ons and I've gota K&N filter to put in. I know I want to reduce the heat and this seems to be the way to go....now if we could just get the stinkin salt off these OHIO roads....I'd go riding!
#463
#464
Wow. Took me most of last night to read through the whole thread, and by then I was too tired to ask my questions, so here I go!
I have the SERT. I have been told the only way to adjust the AFR in CLOSED LOOP is to max out the CLB tables, which I have done. This should be the same as putting the IED in, as both methods adjust the voltage to get the AFR down to 14.1 or so, and it keeps the system in closed loop.
My concern is that on another forum (gasp!) a very knowledgeable poster stated that the narrow band o2 used by HD does NOT like to be far away from it's working voltage (.5?) and maxing it out will cause it to fail in 10,000 miles. As I put 90,000 K (= 50,000 + Miles) on my 02 Standard before trading it in on the 08 Road Glide, and as I plan on putting more than that on the RG, that equals about 5 sets of o2 sensors. The only other option seems to be to adjust the AFR table down to 14.1, which takes it out of closed loop.
Is there a learned opinion on this o2 issue, or is this a new can O worms?
Thanks for all the good reading!
#465
#466
This is just my thinking and nothing to back it up, but the O2 sensors are just sending a signal to the ECM and the IEDs are there to alter the signal. The IEDs should have no effect on the O2 sensors. I think your knowledgeable poster on the other Forum is full of you know what.
#468
Finally got of my butt and ordered mine. Has anyone installed them on a 06-07 FXST, FXSTD, FXSTB or FXSTC? Just curious how to get to the front connector on the O2 sensor. I have the shop manual and it seems like you have to unbolt things by my V&H pipe instructions made it sound like you just unclip something. I looked and feel dumb because I can not figure it out.
#469
#470
