Nightrider O2 IED's - Field Test
Old 03-23-2010 | 06:00 AM
toddcl's Avatar
toddcl
Stage II
Have fitted them on three sportsters 2x 883 1 x1200 down under and very happy with the results
  #3302
Old 04-14-2010 | 12:04 PM
ricaroo's Avatar
ricaroo
Did your mpg go down much?
  #3303
Old 06-04-2010 | 04:29 PM
jokenighttrain's Avatar
jokenighttrain
Well that was a lot to read! Anyway, I've got slip-ons, SEAC, and FuelPak but the bike still runs hot. Can I still use the xied or ied's with the FuelPak or is there an adjustment that can be made to one of the cells on the FuelPak? Or do I take the FuelPak off and replace with the Xied's?
  #3304
Old 06-04-2010 | 04:35 PM
nevil's Avatar
nevil
I used to have almost the same setup and added the XIED's, keeping the FuelPak. I spoke to Nightrider and was told that there was no problem doing this.
  #3305
Old 06-04-2010 | 04:37 PM
jokenighttrain
Thanks, I went to their FAQ and found this.
I have a Vance and Hines Fuel Pak on my bike. Can I use an XIED? Do I need an XIED?
Fuel Pak and IED's have proven to be a very effective combination. Because Fuel Pak is primarily an open loop device and the XiED's a closed loop device, they actually compliment each other. Multiple fuel controllers always has the potential for problems because they can fight for control of the fuel mixture. We always recommend you try to work with your original fuel controller before adding an IED, but the Fuel Pak/XiED combination has proven to be one that is well behaved.
  #3306
Old 06-04-2010 | 05:09 PM
BlockHead96's Avatar
BlockHead96
More problems with the Fuel Pac than worth the troubles, switch to a TTS.
  #3307
Old 06-05-2010 | 07:50 AM
ColdCase's Avatar
ColdCase
Yes, as others noted here.
Just to add that years ago FP +XiED was the hot setup and you would find it recommended by many including several magazines. All the sophisticated closed loop ECU function remains intact and fuel is added open loop.
Starting from scratch there are better options today, however.
  #3308
Old 06-06-2010 | 04:35 PM
Other Sheep's Avatar
Other Sheep
I've had them both on my 07 Heritage for over two years and my son has had them on his 07 WG for the same amount of time. They work very well together. We're both very happy with the performance and less heat. I now have over 28,000 miles on the bike.
I just went on the V&H website and found they had updated the values for my Fuel Pak so I changed to the new settings yesterday and it removed the occasional decel pop that the bike had.
Are there better systems available? Sure, for more money you can get the TTS Mastertune or the Thundermax. Will I ever change mine? Not as long as it works as well as it currently does.
And I got a combined city, mountain mileage of 43 on a 150 mile ride yesterday.
  #3309
Old 06-14-2010 | 11:40 PM
indy74's Avatar
indy74
3rd Gear
Been running XIED's for a year now and I am very satisfied. Still no surging. and runs much cooler.
  #3310
Old 07-20-2010 | 07:51 PM
wlibert's Avatar
wlibert
I just installed the FL-ViED-10's on my '10 Ultra Classic and put about 75 miles on the bike. My ball-o-meter's and my right leg are much happier, the throttle is crispier, and I can easily drive in 6th at 1800 rpms. I set the FL-ViED-10's to 13.7:1 and the bike definitely runs a lot cooler.
Quick Reply: Nightrider O2 IED's - Field Test
