Nightrider O2 IED's - Field Test
#3111
No problem... Here's a small video. The sound is deeper than what the video can produce.
http://s268.photobucket.com/albums/j...t=DSCF0016.flv
http://s268.photobucket.com/albums/j...t=DSCF0031.flv
#3112
#3115
Not sure. They came out of parts Canada last Feb. A friend of mine tried to get a hold of a set in April and was told there was a 6 month wait. I'm sure you might be able to get a set through Drag Specialies.
You should be able to get them cheaper than I could. $1250.00 just for the pipes after duty, shipping ,and taxes. Plus they were new on the market ,which never helps in the price department. I've read somewhere that you might be able to pick them up for around $900 down south. This was about 2 months ago. Might be even cheaper now.
#3116
#3117
Let's go through their FAQ:
Their second conclusion is that it's easier to adjust, though they neglect to inform you that you can use an interface right on the PC-III to perform exactly the same adjustments, probably much easier than with theirs. Sure, you have to hook a computer up to the PC-III to initially set the throttle min/max, but that's got to be way easier than removing (even partially) the gas tank to do the installation.
Their last conclusion is that theirs is "load based" as if any other piggyback unit isn't exactly as load-based as theirs. Any piggyback unit is just as load-based as the unit they're piggybacking.
So, for twenty bucks more, you can have a unit that will do more, interface more neatly with the bike, and is both easier to adjust simplistically and intricately.
No comparison in my book. If you're going to go piggyback, the PC-III is the best bang for the buck besides being just plain the best bang.
The new Ride-Maxx (or whatever it's called) may prove to be a contender as well. I have no familiarity with it whatsoever. I'll assume their bluetooth communication has protective measures to prevent "outside" influence. (Wouldn't it be neat to race for titles against a bike with one of those and switch them into "economy" mode just as they dump the clutch?)
Back to the question. Cruiser has discussed this at length right here in this thread and I believe it would be fair to sum up his take on the TFI as it being snake oil at best.
- Why should I buy your product instead of a Power Commander?
- I hear your product only adds fuel. Some people say you need to remove fuel?
- You say it is easy to adjust. Fuel injection seems complicated to me. What's up?
- What if I install and setup my bike with the TFi and then go up into the mountains? Will I have to re-adjust?
- What if I install other performance mods after I have my TFi? Is there additional costs to me?
- Anything else I should be aware of?
#3118
Now you drag me into a discussion about the TFI making false accusations about statements that I never made. I have never discussed the TFI in any discussion on this entire forum. I hardly know what it is. I have dropped discussing Fuel Mngt. Devices, or haven't you noticed? I challenge you to produce the alleged post where I called the TFI Snake Oil. Time to put up or Shut Up.
Blockhead if you want an impartial answer to your question ask someone who is using it. I don't know much about it, except unlike the PCIII which requires a Laptop, the TFI does not.
#3119
