Nightrider O2 IED's - Field Test
#3011
Don't forget that a Dyno shows more than just HP numbers. It will also show a true AFR curve which would show how well these are working. Just an FYI, I started having some fuel cutoff issues so I removed my XiED's. The problems went away so now I'm on stock AC and no IED's. Fuel mileage is much better and I must say that in comparison, the heat coming off my motor is not much different.
#3012
I have followed this thread from the start and my bike runs great with the xieds.I noticed that the posts just get longer and longer on this simple add on device.This is good though,on nights when I have insomnia instead of taking drugs I simply read a few of these long winded replies and drop right off to sleep. Goodnight.
#3014
#3015
#3017
Berthing compartment, not rooms. We were stacked in like cord wood. Each cubical was 12 men, stack 3 high two deep with a 2' walk thru between the next stack of guys! Essentially, an area 6' wide by 12' deep with 12 people! That compartment held the entire division of my group. Don't remember how many guys, but somewhere around 100 guys. including Officers sleeping berths. Then a small TV room area. Petty Officers and Chiefs had their own small berthing area contained within. Ship had 5000 people on it, todays are a bit larger. Had close to 90 Aircraft, including choppers.
#3018
Again, let me say Thank You for protecting our Freedom.
#3019
You're welcome!
With a ship that big, 5 acres of flight deck and personnel, you can go weeks without seeing a buddy! My entire time on that thing, I never did see the entire ship! If you ever see one in person, up close and personal, it is a incredible sight to see, just the massive size of it all! Flight deck to water line, 90'! Then another 5-6 stories on top of the flight deck, known as the, Super Structure!
Have a look around, I think you may find this interesting. Aircraft of my era.
http://www.youtube.com/watch?v=vl59zFikkzM
#3020
My obsessive compulsiveness extends only to wanting to be entirely clear about explaining what it is they do, how it is they do it, what our EFI does with what they do, who should use them under what conditions, and what everyone else with other conditions should be doing instead. It's not about any animosity or trying to sell other products. It's all about trying to get folks to understand so they can take informed decisions.
