Nightrider O2 IED's - Field Test
#2823
The MoCo implodes!
2010 is the next round of more strindgent EPA mandadted emission laws. I'm just wondering how long HD can continue to use these motors and have them meet all the EPA requirements. They will have to continue to make them bigger to breath better for all the added EPA/CARB BS. I believe the V-Twin as we come to know it is likely on it's way out. I see it all the time in the auto industry. Good example of this, is my Dodge Cummins, thankfully I have the now old 5.9 motor, it has now been replaced with the Cummins 6.7, as the 5.9 has run it's course in keeping up with EPA requirements.
#2825
Why is it in other threads you said you have tuned your bike with SERT? You've event gone so far as to post logs of before and after! If you have done as you have posted before then why was it pinging as you could not put back the original tune to check with, so it must have been your tune in the bike pinging. Something sure smells fishie again.
#2826
Just received the VIED's yesterday and put them on the wife's Sporty. I only went for a little rip, but it is noticably running better after the initial run.
I set the front at 14.2 and the rear at 14.0. Heat is better than before and the bike isn't doing it's 3rd gear hunt as it was before.
The Sportster is running a stock A/C with V&H slipon's with quiet baffels installed.
#2827
I purchased the SERT for the data logging capabilities and the ability to get and reset codes. The bike ECU is still totally stock.
The before and after logs are testing the *IEDs. At one point I had a Rinehart 2-1 but I am stock now and have been for some time.
#2828
@Steve
Both you and a number of other regular participants in this thread apparently have vested interests in tuning and/or after-market activities. From this perspective you are not able to accept that there is a quick and cheap fix in the form of (X)IED's for a number of problems associated with the O2 Harleys, even if they are applicable in only a limited range of stock and nearly stock engines (as accepted by a more broad minded steve mullen of nightrider). What is irritating however are insinuations such as above that other posters are purposely distorting data or even lying. They have no obvious (monetary) incentive to do so, which cannot be said of everybody
#2830
