Nightrider O2 IED's - Field Test
#2811
Where have I ever mentioned excessive pinging? Cold you please show me where all these other problems and "stuff" wrong with my bike?? I seriously doubt you can. You're the only one to claim I have a host of "stuff" wrong, or issues with the bike. Cruiser, your a good guy, but I think your reading into something that isn't there. There isn't any, aside from occasional ping. I'm also re teaching myself to ride this thing, where as, to take the R's higher in the gear before grabbing the next and rolling it on. If I recall, even you had suggested this to me... As mentioned before, my EXIDE's are sitting on the bench, for awhile. I will install them again, just for $hit and giggles and see what becomes..
You're a passionate individual, there is something to be said for that!
#2812
Yes, a lot of passion in this thread. Quite entertaining.
#2813
As for these IED's, I'm the biggest skeptic around, because of my situation with a new bike that pings, I ordered a set of IED's. I want to try it for myself to see if it in fact helps reduce or eliminate my ping, before I go letting the dealer download the heat reduction program. I just can't see how shutting down the rear cylinder when at idle is going to help the ping. I will report if they do anything for me, as I am an opinionated individual!
Originally Posted by Post 2687
After they do the Parade Mode program on mine this Thursday, I too will request a re program of the ECM if PM doesn't help my ping.
Originally Posted by Post 2673
I may try my EXIDE's again once the dealer thinks they have control over my ping issues. I hope to take it in this week and get this ball rolling.. For now, it's wait and see.
Just a Happy Customer
#2814
Well, I think I know what you mean, but put this way it makes one wonder: if the bike is "running right", why would I add this device? Surely you mean, as stated somewhere on the Nightrider site, that the bike shouldn't have major problems and the *IED may help with some symptoms of stock lean conditions on some bikes - there is too much variation to be sure, but at the price it may be worth a try before going the more expensive SERT/SEST/TTS (etc.) route.
Thanks...
Just a Happy Customer...
#2815
Once again, the occasional ping, is my only situation I have ever had, period! I'm still not seeing any other "stuff" that is wrong with my bike. Post 2687, means exactly that, if the ETH flash doesn't help, I would suggest to the dealer for a re program of the OEM program. Hasn't come to that.
My bike has NO major problems as you wish to suggest, the EXIDE's claim to help reduce ping, they did NOT.
#2816
The XIED's can reduce pinging of course that depends on what is the underlying cause.
#2818
Thanks,
Dave
#2820
Cruiser, no problem. I know you have good intentions!! On a side note, there is NO underlying issue! It is what it is because, of EPA. They are all to lean, hence the heat issues and surge. This is nothing, wait till the 2010's come out, then I wouldn't be surprised it is at least a 103" motor!!
