Nightrider O2 IED's - Field Test
#2701
I believe Steve at nightrider calls this limp-home mode, or something similar. It's a "failsafe" over-rich setting.
By the way, did you notice yesterday (maybe the day before, now) where Steve had said what I have been saying all along? Seems the corner you said I was in all by myself is getting a little crowded...
#2703
#2704
271 pages and what have we learned???
Works on some bikes and not so well on others.
Some bikes throw codes with them installed and some don't.
Some say the codes are a bad thing and some say they don't matter.
Rider57 says the ieds/xied's have no effect on open loop and glens and now steve cole says it does.
And Nightrider says nothing either way.
Some say it makes the bike run too rich (my case) and others say too rich don't hurt anything.
Some say it runs cooler and others say no difference.
And most importantly... has anybody actually tested them on a dyno at different throttle openings on a bone stock bike to see what the AFR values actually are and if they actually effect the open loop? .... Without searching back 270 pages to look again.
Jim
Jim
#2705
#2706
Dyno sheets posted before. Bike is stock Road King CVO 08 with XIED's from new. WOT test and 2,5 volt throttle. As stated in earlier posts I we also tested at constant speeds under load to simulate road conditions. AFR was approximately 13,8 with a spike due to opening and closing of exhaust valve (international model). Did not get presentable print-outs from testing at constant speeds.
#2707
Jim
Jim
We have a winner!
It's all a crap shoot, be it IED's or fuler's, one thing for certain, you will hear from no one defending or explaining their product.
#2708
Actually it is not a crap shoot. Look a the dyno! I am from Europe and have no relationship with Nightrider whatsoever, but I bought his XIED's after I read about heat and lean burn problems with the 110's. I inquired about various products such as PCIII, ThunderMAx SERT and others, but backed off because almost everybody told me a different story. I decided to keep the bike stock to begin with and take the XIED's as a kind of insurance. The bike has approximately 1750 miles on it (sometimes relaxed cruising but also longer 120 mph stretches on the "autobahns"). Since the American Iron article about the S&S quick tuning kit wich stated that the ECM can adapt to a mild tune (AC and slip-ons), I have decided to try an AC upgrade with the XIED's. It will be installed shortly and I will post the dyno results here. Personally I do not understand the quarreling in this thread. The only issue is whether the XIED's are too rich in open loop. The tests that have been done (Rider57 Whittlebeast, mine) all show that it is not. Glens states the opposite from a more theoretical perspective. All I know is that my bike runs very well and does not have any problems untill now.
#2710
Looking at my logs it is easy to see that the stock dithering algarithem is still getting leaner than 14.7 with the ViEDs. The osolating pulse width change would indicate an AFR swing of about 1 AFR or down to about 13.7
see http://www.ncs-stl.com/XIED/StockVsXiedVsAdj.jpg
