Nightrider O2 IED's - Field Test
Old 07-26-2008 | 07:09 PM
cruiser85257's Avatar
cruiser85257
Default RE: Nightrider O2 IEDs, Field Test
I'd love to know how you can write a post on here without any problems.&nbsp\\; Yeah, yeah, I read your comments.&nbsp\\; They don't work for me.&nbsp\\; I can't effectively respond back till they fix this forum.
  #2372
Old 07-26-2008 | 07:18 PM
diebolt's Avatar
diebolt
I have tried for days to post with no luck
The way I got this to work is to first post a message with one word "test"
Then go back and edit to add more to the post.
  #2373
Old 07-26-2008 | 07:21 PM
glens's Avatar
glens
ORIGINAL: Mr. Lucky
What is going to happen the first time you disconnect/replace the battery? Dont the values get reset?
That has been discussed recently in another thread. I do not know if it does or to what value it would if it did, I never had the ECU disconnected from the harness a sufficiently-long time and had/have no way to read them myself. What I did likely did not get them to 100%, rather to an adequate value for the conditions and fuel I was using that day. Until the new TTS tuner, from the makers of the SERT, the only way to read the values was with an H-D Digital Technician. The new tuner is evidently able to read/reset the AFVs now, too.
  #2374
Old 07-26-2008 | 07:47 PM
glens's Avatar
glens
ORIGINAL: cruiser85257
I have an uncanny ability to figure out technical things. Not so great with people...
Lose the apostrophes and you will have better luck. Notice also in the attached image file how I have my incoming proxy re-write the pages from here to clean up the text before I ever see it.
[IMG]local://upfiles/36555/BB68004A0DAE453FADB1FF5132F2A381.gif[/IMG]
  #2375
Old 07-26-2008 | 08:24 PM
cruiser85257
ORIGINAL: glens
What do you mean by incoming proxy?&nbsp\\; I have tried everything Glens and I cannot get it to work.
  #2376
Old 07-26-2008 | 09:54 PM
loc's Avatar
loc
I have some XIED's for sale. Just installed Super Tuner today because I plan on going to cams and 103 inch in the next month or so. email is tmpgh at comcast dot net. I will do a fair price for you. These were on the bike for about 1000 miles.
  #2377
Old 07-27-2008 | 12:26 AM
glens's Avatar
glens
ORIGINAL: loc
If you had the option of SERT with Canned Map or XIED. Aside from money, what is the better choice and why. Assuming bike is stock now but going to 103 and cams in the winter...
The SERT, hands down. Why? Because you will be able to properly use the ECU to its fullest capabilities. Just be sure that the parts you have assembled are specific to the canned map if you are not going to use a dyno to accurately populate the VE tables to your parts. I do not know what the map you have in mind is for. You will have to determine its appropriateness without my help at this time.
  #2378
Old 07-27-2008 | 12:29 AM
glens's Avatar
glens
ORIGINAL: loc
I have some XIED's for sale. Just installed Super Tuner today...
Ha! I did not look at the most recent version of this thread before submitting that last post... Smart choice, congratulations!
  #2379
Old 07-27-2008 | 12:46 AM
glens's Avatar
glens
Well, we are getting pretty far afield from the topic, now...
Did you like the presentation of your post in my image? I am stuck on dial-up where I live. I have a web-cache behind another program which re-writes incoming pages as I direct it. Various things done for various sites. For this one, I have it remove run-on combinations of apostrophes and have it convert the bastardized HTML entities back to their original forms. Notice the double spaces between your sentences in my image. Really cool stuff, but well beyond the scope of this forum, let alone this thread. If you think my previous posts were too technical you really would not like me to expound further on this.
  #2380
Old 07-27-2008 | 12:09 PM
kylant's Avatar
kylant
advice needed.
i have an 08 rocker with v&h big radius pipes. the rest is stock. the bike is hot... plug readings done last night after a ride, temp about 95*, shows very lean. plugs were white.
i eventually will do an intake and full tuner upgrade, but money needs to be spent on other things right now.
will xieds temporarily richen me up? temporary band-aid fix for the leanness? or is there something else i should do?
when tuner time comes, should i get the Super tuner and have a dyno tune done, or get the Thundermax with auto tune? they are about the same cost
thanks
Quick Reply: Nightrider O2 IED's - Field Test
