Nightrider O2 IED's - Field Test
#2311
RE: Nightrider O2 IEDs, Field Test
ORIGINAL: RenoGlide
>> Since my post numbers are way down... Im guessing my "street cred" may lack merit... as if I care, LOL
>> Definately not my first rodeo ....
You have the right idea. Just get a proper fuel management system for your modified breathing stuff and be done with it. These things are largely-acceptable patches only when used with factory parts packages.
#2312
My 07 superglide is one of the good ones,NO problems with heat,trans.whine,drivability etc. I'm conservative but just had to install slipons for better sound.I was worried about running too lean so I installed Xieds.The motor did run stronger,sound better and after 1500 miles the plugs look perfect.There will be no further changes made.
#2319
ORIGINAL: billybud
plus...and I wonder why..I think that my stock exhaust has more rumble... "placebo effect"....or real? \\;\\\\\\; Dunno.
It's real, one of the first things I noticed as soon as I installed the IEDs. \\; Sounds better and runs better. \\; Not any noticible change in oil temp. \\; \\; \\; I'm running totally stock.
#2320
