Nightrider O2 IED's - Field Test
#1801
#1802
RE: Nightrider O2 IED'
ORIGINAL: ultraJohn
My HD dealer parts guy that seems to know his stuff has told me that my XiEDs are going to F-up my plugs and will void any warranty claims. Has anyone had plug issues? I will remove the XiEDs when I take it in next week for it's 15K service.
#1804
RE: Nightrider O2 IED's - Field Test
ORIGINAL: elpoman
 \\;I asked the same question, about the b codes, and it seems to have something to do with the ABS system. \\;\\\\\\; I got a C1095 error code, and had to ask around on the forum, about it , and found out it was a front brake switch code. \\;\\\\\\; I have cleared it, and am waiting to see if it comes back. \\;\\\\\\;
#1805
So we just had 4 straight 90+ days here in the Boston area and I can honestly say that in a combination of stop and go/highway driving that my bike runs much cooler. Though I could feel the heat on my right leg, it was never uncomfortable. I'm running the IEDs on my stock 08 EGC and have been very pleased with the changes since installing them. I do have a question about the codes though. Are they stored in the system and do I have to go looking for them? Would they pop up as the error occurs then go away? Can you get codes without a "check engine" light? I'm still pretty new to Harley, so pardon my ignorance. I will take the IEDs off for the 1,000 mile service when it goes in. I'll also be switching to synthetic in the tranny and motor which should also help heat wise. But I'll put them right back on when I leave the dealer. Thanks for your help.
Joe
Joe
#1806
Well, with the mention of failed spark plugs in the above post my ears perked up when the service writer told me that mine had failed.
I had my bike out last weekend and it \\;started running bad so I removed the Xied wires and still bad. I went to a dealer in the area \\;and they test road it but couldn't put it on a rack for over an hour. I decided to take the bike to my dealer and they checked it out today. The service manager said the spark plug failed. I did not mention about the XiED wires at all. I did tell him that I had pulled both plugs and that \\;they looked OK. He said unless I turned them upright I would not have seen that the center electrode was loose and sliding down and shorting out. With a new plug it runs great and I will install the wires tomorrow.
So I am glad that it was the plug failing because of something else and not because of the XiED wires.
#1807
MotorMedic
Here is the code info
http://personal.linkline.com/cdesigns/Error%20Codes.pdf
#1810
Just for fun, I ordered a couple of versions of these to test on my totally stock Sportster. \\; I will data log it with my \\;SERT and see what sort of changes come about once the stock ECU homes back in. \\; This is going to be fun  \\; I am also going to get a set of o2 eliminators to play around with. \\; I will post acceleration runs to see what they really do for Torque.
AW
AW
