O2 sensor blanks
O2 sensor blanks
I,ll be fitting a Power Commander soon (its on order from Fuelmoto) and i,ve read its best to remove the O2 sensors as they will be disabled. Anyone know the size of the blanks and where to get them, or are they nothing special and a couple of cutdown bolts will suffice.
Any advice guys?
Any advice guys?
RE: O2 sensor blanks
If you really want to plug the O2 bungs it is M18-1.5. Good luck finding a bolt that size. Seach ebay, Jeggs or Summit Racing.
http://cgi.ebay.com/ebaymotors/PAIR-...em370020493013
Leaving a disabled O2 sensor inwill eventually ruin it because it no longer has it's heater circuit enabled thatwill no long be able to helpburn off the exhaust contaminants, if that is a concern.
This thread has you answer to the plug size.
https://www.hdforums.com/m_1638262/tm.htm
ORIGINAL: cornishman
Hi Gundog, this is what i read on another thread.....Leaving a disabled O2 sensor inwill eventually ruin it because it no longer has it's heater circuit enabled thatwill no long be able to helpburn off the exhaust contaminants, if that is a concern.
AW
Whittlebeast is right, one and two wire o2 sensors are not heated sensors. They rely on the exhaust heat to bring them up to operating temperature. That is why they are located close to the exhaust port in the head. Three and four wire sensors are heated sensors.
Arcane
Arcane
