PC111 USB Sudden Drop In MPG
07 RG PC111USB with map from fuel moto, True Duels was getting 40 MPG at 75 MPH 2 up riding, now out of no were 30 MPG same riding. So pulled it out added the 02 senors back in the headers and pluged the stock ECM back and installed the stock air filter. Back to 40MPG,same riding, also have an oil cooler and tank temp stays at 220* when hot, but pipes are alot hotter. Seems to be a bad PC, what do you think. Thanks Doc
RE: PC111 USB Sudden Drop In MPG
Thats good gas mph with true duals and pc3 with 2 people On a touring bike. Idont see that with most touring models most off the time 38or less but. You should talk with Jamie at Fuel Moto Ask him to take a look at it for you he can test it to make sure theres nothing wrong with it. call Fuel Moto1-877-729-4754 Also were the SER/# Is look at the right side see if its giving you any codes also call power commander they can help. Or send me a screen shot withbike running with pc3 I can try to help you.
FRANK FROM D.B.W
FRANK FROM D.B.W
Thanks Frank. No codes showing on the Laptop with PC connected and bike running. I was getting an average of 40 MPG Then all of a sudden low 30s same riding same fuel same speed and weight. Called Jamie, will be sending it back to him for a look see. Thanks Doc
Notgrownup
08-03-2014 07:27 PM
