LC1 WBO2 Kit from Nightrider
Anyone up here tried the LC1 WBO2 kit from NightRider. Apparently it replaces the stock Narrow Band sensors with Two Wide Band sensors and can either be purchased with a fixed AFR of what ever you want (They mention 13.5 or 13.1), or you can buy the units and do your own adjusting. Looks interesting for $398.00.
RE: LC1 WBO2 Kit from Nightrider
I use an LC1 for tuning purposes on my car. I thought they were $199? http://www.innovatemotorsports.com/products/lc1.php
Anyways, I would NOT REPLACE the stock O2 (and leave them in so they can do their job!) but I would add the WB02 in the exhaust for tuning purposes (realtime / live / data logging A/F) and then adjust ECM based off of your data. Thats if you care that much.
FYI= my 620hp twin turbo car runs two narrow band 02 in stock locations with a single WB 02 for tuning. I have a $1000 Apex-i ECU running my car with on board boost control and more adjustablilty than you can imagine. It still needs to be tuned on a proper dyno to be dead on. Even with target A/f functionality (what is called "auto-tune" in the aftermarket HD ECU market)
Actually, to us, monitoring fuel pressure is 10 times more important than AF. But thats a different sotry.
Iron lHorse
01-25-2014 07:41 AM
