Questions regarding Stage I, '07
Okay, being new to HD air cooled, I have a question or two about what I think is called the "Stage I" upgrade. I picked up a set of HD Screamin Eagle slip-ons for the wifes '07 Softail Deluxe on the cheap. I need to know, before I get the ECM remapped, what should I do on the intake side? Do they make a simple screaming eagle high flow filter replacement? I did see a SE Stage I air cleaner on the HD website, but at $140 is kinda pricey. (for me at least)
Thanks
Greg
Thanks
Greg
RE: Questions regarding Stage I, '07
I have seen people only replace the element with a high flow element while using the stock backing plate. The cover will not fit back properly if you go this route,it leaves about a half inch of the filter exposed on the backside where it meets the backing plate. If your looking for a complete kit its gonna be 150.00 and up depending on which one you go with. And if you dont do the install yourself you can add a half hour labor to that (35.00).
Thanks Guys. All helpful. Keep 'em coming.
So, if I use an aftermarket kit, like the big sucker, will my HD dealer know how to remap it?
I have no problem installing something like an air cleaner or the slip-ons myself. A follow up question would be; Can I run the bike for a short time with the intake and exhaust mods, and before a remap, without damage?
Thanks Again
Greg
Thanks Again
Greg
