Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Whats up guys
Does Stock twin cam EFI motor benefit from better plug wires
(IF so which ones) and as far as the plugs go I have had great results in past bikes(not HD) and performance cars with stock replacement NGK iridium's.
One thing to keep in mind that if you use wires the emmit RFI and you ahve a efi bike th at is will cause issues. Seen it been there. I do not recall what wires they used but they where a H/P type wire
Changing wires to a different type or the plugs to a different type can also set codes and defeat the ion sensing system that eliminates pinging by varying the resistance in the secondary ignition circuit.
