engine light at start up
Old 01-08-2006 | 09:40 PM
UltraScoot's Avatar
UltraScoot
Default engine light at start up
on my 06 I turn run switch to run position, turn ign. on, then wait for engine light to go off befor starting... Now I noticed to day and after installing commender PCIII/usb afew days ago that after doing the steps mentioned above; the light goes off then I start engine and about 3 seconds later it comes back on again then goes off after just a couple seconds. also if I do the above steps but dont start engine right after light goes off the light will come back on a second time then go off after a couple seconds. someone please tell me if this should be a concern to me.
Old 01-08-2006 | 09:45 PM
Terry TK's Avatar
Terry TK
Big Kahuna HDF Member
Default RE: engine light at start up
It sounds like you have thrown a code of some type. Probably has to due with the install of the PCIII but it shouldn't be a problem. Check the Tech Forum. There is a lot of info there about the codes and what they mean. I'm pretty sure there is something there that tells you how to reset them. If it happens again I would have my dealer check it out.
Terry
Old 01-08-2006 | 09:50 PM
HDF Tech's Avatar
HDF Tech
This is not uncommon at all, You have a code set, check this thread to pull the code and also how to reset it... https://www.hdforums.com/m_43975/tm.htm
Old 01-08-2006 | 10:07 PM
UltraScoot's Avatar
UltraScoot
I noticed this above post speeks to 04 - 05 bikes only, I will think it applies to my 06 also? and give it a try, will also check tech form in future... thanks alot guys for info.
AdrianVall
09-06-2011 04:44 PM
VRodRider
VRSC Models
16
09-04-2007 02:52 PM
KeithB
Exhaust System Topics
17
11-02-2006 09:48 PM
notarheli
13
09-21-2006 07:45 PM
20NightTrain03
07-06-2006 12:00 AM
Quick Reply: engine light at start up
