SERT, What is it?
Old 01-08-2006, 08:06 PM
HDF Tech's Avatar
HDF Tech
HDF Tech is offline
Default SERT, What is it?
Submitted by: springer_ (V Twin Forum) & www.bigboyzcycles.com
More DIY topics and info on the SERT... HERE
WARNING Objects in this post may seem more confusing than they really are.
This post is not to teach you everything you ever wanted to know about a SERT. Instead it is to give you some insight into what a SERT is and what to expect. The SERT version used is 4.12. If you have specific question about the SERT, I would suggest you download the PDF file at the end of the post, it is the SERT manual.
I am NOT an Expert on the SERT and have only used it a few times but found it considerably less intimidating than it looks at first glance. I may make some mistakes in terminology and definition as I am NOT an EFI Expert. If you have specific knowledge about something please post your info. I will not argue the facts of this post but I am willing to learn so if you find a mistake please point it out.
This is my take on the cost. You pay a little more for the EFI bikes. Then you buy the SERT. If you bought a bike with a carb and wanted to do performance mods, most likely you would be buying a new carb to the tune of about $400. You would also need a new ignition module, another $200. If you didn’t like the results or achieved unexpected results and wanted to try something different, mo money, mo money, mo money. With the SERT if you don’t like the results, you just upload another MAP.
The SERT is a program that you load onto a desktop or laptop computer. It allows you to modify all aspects of the fuel and ignition control module called an ECM. A nice part of the SERT is that you can play with the MAP’s anywhere. If you have it loaded on your laptop and you are at work bored for instance you could mess around with a MAP and save it for later.
Another bonus with the SERT is how easy it is to load a MAP. You simply plug the computer into your bike and upload it. It is very fast and easy. I can upload a new map quicker than you can get the air cleaner off a carb, let alone remove the float bowl and the jets.
There are some issues with using a SERT. The first one is getting your SERT to communicate with the bike. The first time I used one it would not work with the ECM. It gave an error trying to read the VIN number of the bike. If you have this issue you need to take the bike to a dealer and have them reload your VIN number into the ECM. Convincing the dealership mechanics that this is all you need, will be the next problem. This problem seems to be in the earlier model Delphi ECM’s, 01-03.
In this thread we will be using the word MAP and it will refer to two completely different things. The first meaning of MAP as used up to this point is like a road map. Depending on where certain conditions are met, it tells the ECM what to do or where to go like a road map. The second MAP stands for Manifold Absolute Pressure. Try not to get too confused between the two. (note one sentence using to, too and two )
After you install the SERT and the user manual, you will have 2 PDF files on your desktop. One is called “Race Tuner Cals” and contains some basic engine setups. Choose the one that most closely matches your build. This is your BASE MAP. When using Big Boyz Street Heads, we recommend selecting a setup that uses SE Performance heads in the configuration.
Here is an example of what the chart looks like.
After selecting the base MAP for your build and opening it, you will see a screen like the following picture. The base MAP opens in “Basic” mode. In Basic mode all the numbers on the MAP chart are 0. The zero represents the default setting and then can be changed by PERCENT. I personally don’t like this mode.
1) Indicates the RPM range
2) Is the MAP (Manifold Absolute Pressure)
3) Green table values indicate LOW Limit (
Old 03-29-2013, 02:30 AM
Inmyblood's Avatar
Inmyblood
Inmyblood is offline
If you are going to spend the money on a Screaming eagle Race Tuner I would not try and program it yourself, you could do a great deal of damage to your engine. that is why you see the red light in the SE parts book this is not for every day tuning but for larger displacement engines and race applacations and should be done by an experienced tuner and put on a Dyno for a custom map. If all that is done you will be able to tell the difference in torque in your modified sled. Be Careful
Old 03-29-2013, 02:58 PM
UltraNutZ's Avatar
UltraNutZ
UltraNutZ is offline
dang man.. brought back to life a 7+ year old thread. And FWIW, the SERT and SEPST are very adept to DIY tuners. Just gotta read, understand, and ask questions just like with any other tuning device.
paolu79
07-11-2009 01:37 PM
supernova
04-27-2008 05:31 PM
jasonfish
11-20-2007 10:57 AM
Phast Lap
10-11-2006 12:45 AM
Indianspringsaz
09-29-2006 05:46 PM
Quick Reply: SERT, What is it?
