Run with mods?
Run with mods?
I need some opinions before I might ruin something. I've modded my 05 Road King with a SE Stage I A/C, SE Touring slip ons and will be converting to True Duals with a Torres kit. I know that it needs remapped, but I'm not sure what direction to go in. I could buy a PCIII or a SERT and do it myself, but can I run the bike long enough to get it to my nearest HD dealer and let them do it? My concern is I might damage something in the process. The closest HD dealer is 40-50 miles from me. I really don't plan on making any other changes, so the PCIII or SERT seems to be an expensive route. I have no clue what HD would charge me to do it and will the ECM be able to be returned to stock. I am hearing not. Any opinions or comments would be greatly appreciated.
Thanks,
Roger
Thanks,
Roger
RE: Run with mods?
Hey Roger,
Does your bike has stage 1 download?
I am in the same situation as you, or maybe more...
05 RKC
Stage 1 A/C
SE Touring muffles
203 Cam
Stage 1 download.
I am changing my header to B&E true Dual though.
I have heard about changing to true dual(either V&H, Fullsac, Torres, B&E) will cause Engine Check light to turn on on FI bike.
Not sure if it is true....
Do keep each other posted on the "upgrade" here....
05 RKC
Stage 1 A/C
SE Touring muffles
203 Cam
Stage 1 download.
RE: Run with mods?
I have no download yet. The stage I A/C is in and the Torres true duals will be ordered probably today to go with my SE Touring slip ons. I plan on installing it all myself and then taking the bike to HD to have them remap it. I don't see any need at this point in buying a SERT or PCIII because I don't plan on doing any further modifications. I was just concerned about causing any damage to the bike on the drive there.
Roger
Roger
RE: Run with mods?
With these Changes you do need to have your Bike Remappedmainly because of the Cam Change.
ORIGINAL: hoelwill
Hey Roger,
05 RKC
Stage 1 A/C
SE Touring muffles
203 Cam
Stage 1 download.
Hey Roger,
05 RKC
Stage 1 A/C
SE Touring muffles
203 Cam
Stage 1 download.
RE: Run with mods?
ok ok IceHeritage, you just made me stood up from my chair and getting a little nervous right now, coz i am holding on to the 2 pipes on my hands...
I have already had stage 1 map downloaded to the ECM when the cam was changeda year ago. It didn't pop, knock, ping whatsoever. I thought i am pretty happy with it.
Read the plugs too, ceramic is good, except the metal ring part has a little build-up of black stuffs.(can be scrapped away)
So if i need to remap/redownload a new map due to the true dual change..pplease let me know..meanwhile i think i will hold on to the pipe swap, which was suppose to start a few hours later... Thanks!
