Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Hi,what map should I use from SERT J version for a 113 TC,S&S 585 cams,10.5 comp,RH 2 into 1 exhaust,stock TB,something to use as a base map for break in.Looks like file #141NL003-A2 is close other than it shows a 50mm TB,or maybe a super high output 1690 with 2-1 and stock TB would be closer,thoughts?
Thanks
Mike
sounds like to me you should have a custom map done.i know it may cost a few bucks .but for the work you have done you should get the most out of what you got. just my 2 cents.
I agree,custom map would be the way to go however when there aren't any SERT capable tuners nearby,you have to make do with the resourses you have.
Mike
