Anyway to check rpm's with a multimeter?
RE: Anyway to check rpm's with a multimeter?
ORIGINAL: rbabos
Not without an adapter that reads induction from a sparkplug lead and plugs into the multimeter. SnapOn has them but not cheap. Not sure about other brands.
Ron
Ron
ORIGINAL: murphdog
If one of those unused wires is a tach signal, it's going to be a pulse train signal not an analog signal. If your multimeter has a frequency range, you can measure it...an AC or DC voltage range won't work.
http://www.sears.com/shc/s/p_10153_1...rms+multimeter
It has a frequency range so I am guessing it would work...?
How would I find out what reading is what rpm?
That metercan dofrequency, so it should work. Page 20 of the owners manual tells you how to do frequency measurement (ignore the % duty cycle stuff). I would set the meter on the 50Hz range for checking idle rpm. The meter will read in Hz (pulses per second), so just multiply by 60 to get pulses per minute or rpm. 16.67Hz would be 1000 rpm.
ORIGINAL: murphdog
-Matt
