Tmax 4.5 firmware
Tmax 4.5 firmware
Hi
Can anyone tell me how to get the latest 4.5 version of firmware for my Tmax?
I have tried the online D/load but can only get the 4.4 version for some reason?
I have some slight decel popping and want to use the new functions in the 4.5 to addres this.
2007 Softail FXS
A/N Bigsucker
SE Street legal(Baffles cut)
TMax.
2007 Softail FXS
A/N Bigsucker
TMax.
RE: Tmax 4.5 firmware
4.4 is still the official current release. 4.5 has been given out at shows, but has still not been "officially" released. If it is not on your disk, you can call Zippers and ask them for it, but they have not posted it yet.
When you are linked, take a look at the "About Smartlink tab at the top of the page. It should show both the Smartlink and Firmware version numbers.
Think I have solved my own problem!
Decided to re install the original s/ware disc on my computer and when I did this the relevant features of the 4.5 firmware were there and operable?
When I do the "about Smartlink tab it does not say 4.5 version just a date of build? eg:- 2007
So I can only assume it is the latest version.Have also done the web update feature.
I will re load the map tommorow with the decel fuel ajustment enabled and see how that goes.
I assume I will have to clear all learned offsets first and re initialize and then do the learning thing again?
ORIGINAL: ajayrk
System refuses the file when I try to upload it, so an email seems to be the only way. I can foward the email I got from Zipper's Support. Let me know.
