Damn Lying Volt gauge !
Ok...95 Ultra. Volt gauge will read around 12 volts usually and sometimess less iif running the radio. Pulled my seat and checked voltage at the battery 13.4 volts at 2k rpm. Gauge says 12 volts. I thought the gauge needed replacing so I bought a new one ($48 for informational purposes) Put it on and it reads 11.5 to 12 volts. Checked the wiring diagram and saw the meter went through to the terminal block with a fuse. getting the same voltage there that the meter is reading. My digital meter on the batter indicates the system is charging and since it hasn't left mwe anywhere it must be. But why the low voltage at the gauge and at the fuse box? Any ideas? Places to look? things to check?
AS with any older bike, I had a number of nicked, chafed wires to fix. Done that but no matter what I do, no volts on the gauge never go above 12.5 even though a check at the batter sayd 13.4 PS I replaced the main circuit breaker already.
Help
Bubba
Help
Bubba
Checked output at my passing lights and it is the same as the gauge reads, about 11.5 with nothing running. Checked at the headlight 11.5 Everywhere I check a hot leg it's 11.5 except at the battery. Is there a particular bus where power goes from the battery to the different harnesses? I got the service manual but all them damn fine lines in the wiring diagram run together after a couple of beers. It just appears that battery voltage is not getting to the fuses under the fairing but having voltage drop along the way. Bike has never left me due to dead battery.
Help !!!
Bubba
Help !!!
Bubba
Damm!!! gaugesmaybemade in China. LOL LOL. You get a higher reading at the battery then the head light or some where else. Sometimes the further away you go from the main source you lose a little.A real good volt gauge like daytonaare real good. but are a lot of money. Just make sure that battery is getting 13 or higher with a volt meter and turn on the lights turn signal etc. to see how much it drops.Then rev up rpm and watch volt meter.
I hope this helps...
It seems like as these bikes are getting older, there are more voltage drops in the wiring, terminals, etc. The real problem is voltage drop between the battery and the gauge, thru the wiring. Ever notice how the voltage on the gauge steps down when you turn the headlight on, or brakes? The error between the gauge and the battery voltage gets worse as more current is drawn. Ohms law. I added a relay under the sidecover for the brakelights, so they dont cause the indicated voltage at the gauge to read any lower, but you can still see the turn signals, even when you turn the stereo up the gauge reads lower, but the battery voltage reads good. What I ddi on mine was to turn everything on, with the engine off. Let it sit that way a couple of minutes, and then touch all the connections you can, up in the fairing. I felt a couple that were hot, one was extremely hot. That means they are dropping voltage. Clean up and replace them, and it should help somewhat. Also, check the wire from the battery to the main breaker, and both battery grounds, including the braided one under the trans.
