Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Hi Guys, I have a 02 Dyna Wide Glide carb model and the speedo now has a mind of its own! When i start off the speedo flucuates and then stops or sticks and the engine light comes on but the bike still runs perfectly....but i have noticed that when i pull the clutch in everything works normally...the light goes out and the speedo works fine again until i let the clutch out and sometimes it carries on working for a while and other times it stops right away?!?!....Anybody had anything similar. Not sure if its the speedo itself or the sensor
I don't have a Dyna and have never looked for one on a Dyna, but I'm sure it is similar to one on a Dresser. It will be on top of the transmission. It is just a small unit with a wire running to it and will likely be held down with an Allen head bolt.
OK, thanks i will have a look tomorrow and try cleaning it ...will let you know if it cures it...any guesses as to why it works with the clutch pulled in??
