HD and Panacea
HD and Panacea
I picked up the HD Run, Brake and Turn module for my 07 FXST and installed it. I was looking at LED turns when I noticed the Kuryakyn Panacea rears will do the run, brake and turn but light up yellow for turns. Has anyone tried these lights with the HD unit will it work the same?
RE: HD and Panacea
If you are interested in really bright LED lights, you can't go wrong with www.heavycycles.com
They are a bit pricey, and the lead times pretty long, but his work is awesome, and they are BRIGHT.
RE: HD and Panacea
Thanks for the replies. It seems the HD unit just changes the voltage to the lights and thats how it gets run & brake out of a single element bulb. I figure this is how the Panacea unit works so I thought it may just work without buying the Panacea brake light as well. I want to go with the tri bar from harley. I guess Ill be the first to try it and let everyone know.
Trapperwny
08-11-2014 09:28 AM
