SERT cables
Ok, I got my brand new in the box SERTbut it didnt come with cables. I already went to Best Buy and got a serial port to USB cable to go from the tuner to my lap top. What do I need between the tuner and my bike? I only called one stealership and they told me that you cant buy the cables between the tuner and the bike, I hafta bring it in to them to be installed. I know thats a load of BS but can I get the cables aftermarket or does it hafta be froma dealership?
thanks
thanks
ORIGINAL: drdiesel1
That's total B/S....[:@]The dealerhas a kit, but I don`t know the part #. Call another dealer. That dealer is a rip-off.
That is a crock of ****.
Order from Zanottis Motorsports or Hales HD in Ohio.
I think the part number is: 32108-06: is the SERT cable kit (MSRP $29.95)
You will get the cable for the bike, and the Serial Cable. Be careful with the Adaptor you purchased. I use the Belkin USB to Serial adaptor and it works well. Others are kind of hit and miss. You can get the Belkin version from Office Max, or Office Depot. I forget which one I got mine from.
Best of luck.
RJ
Best of luck.
RJ
32108-06 is the correct part # for the cables.
Problem solved. After getting the part # for the cables,I went back to the stealership. I just gave them the part #and got the cables. Didnt mention in any way it was the SERT cables I wanted, only said part #32108-06 and got it no problem. Came out to $31 after tax, not a bad deal. Returned the adapter to Best Buy and everything worked out.
Thanks for help everyone.
You returned the adapter......so....that means that your laptop has a serial port? I've been looking at laptops and seems alot of the new ones don't have serial ports any more. Also, on the subject of laptops......anyone use their sert with a system that operates on Vista?
ORIGINAL: LMeyer327
