SERT 32107-01G Help Please
Old 11-16-2007, 06:16 PM
Herr Monk's Avatar
Herr Monk
Herr Monk is offline
Default SERT 32107-01G Help Please
Will this work with my bike? '07 FXDL?
Says it will, but I've seen 32107-01H and 32107-01J
what's the diff?
Thanks
Old 11-16-2007, 06:24 PM
Herr Monk's Avatar
Herr Monk
Default RE: SERT 32107-01G Need Help Fast!
Well I won it on ebay, so I hope it works...
Old 11-16-2007, 06:28 PM
Doc 1's Avatar
Doc 1
Doc 1 is offline
The SERT will work but you will need the "J" software for the 02 sensors
Old 11-16-2007, 07:56 PM
Herr Monk's Avatar
Herr Monk
How do I get that?
Old 11-16-2007, 08:37 PM
UltraKla$$ic's Avatar
UltraKla$$ic
UltraKla$$ic is offline
ORIGINAL: Herr Monk
How do I get that?
Go to your local dealer and tell them you want to buy the "J" software for the SERT. Cut the check for $20 bucks and you're done.
Old 11-16-2007, 08:39 PM
Herr Monk's Avatar
Herr Monk
Thanks. Sounds simple enough. I also understand I might have to buy wires?
For $300 still feels like a good deal
Old 11-16-2007, 08:51 PM
Duracell's Avatar
Duracell
Duracell is offline
Received 1,659 Likes on 581 Posts
You will need cables. The dealer has the ones from the bike to the sert. If your computer was built in the last hundred years it won't have the serial port that the sert needs so you will have to buy a serial to USB adapter. Ive heard some brands don't work as well as others so you may want to do a search and find out which ones work.
Old 11-16-2007, 09:15 PM
SGDude's Avatar
SGDude
SGDude is offline
this little baby right here works well. it's the same as what some vendors sell with their tuning software.
Old 11-16-2007, 09:36 PM
Herr Monk's Avatar
Herr Monk
Why don't they just use USB?
Old 11-19-2007, 11:28 AM
Herr Monk's Avatar
Herr Monk
Any Map recommendations of an 07 with SEIIs and Stage I big sucker?
Quick Reply: SERT 32107-01G Help Please
