noise suppressor for audio
Old 11-09-2007 | 10:07 PM
bikerbehaviorist's Avatar
bikerbehaviorist
Default noise suppressor for audio
I am installing some powered speakers and getting noise I have an old suppressor but can not remember how it is wired. There are 3 wires red, blue and black. I believe the red and blue are hot they are on opposite sides of the filter, does the black go to ground?
The supressor looks like
[IMG]local://upfiles/5188/72C2AD8C043349F393EE1D7452E91C24.gif[/IMG]
Old 11-09-2007 | 10:50 PM
AmphibSailor's Avatar
AmphibSailor
Default RE: noise suppressor for audio
From what I've read, you're right. The black goes to ground. The picture above shows one installed between the alternator and battery. The little tab is screwed into the chassis and is the ground.
The link below leads to a nice write up for checking out noise in stereo installs.
http://akamaipix.crutchfield.com/ca/...oise_guide.pdf
Are you going to install the suppressor between the amplifier and the power source?
Old 11-10-2007 | 04:22 AM
bikerbehaviorist
Thanks great links!!
Old 11-15-2007 | 02:41 AM
AmphibSailor
No problem. Hope it helps!
Loujr28
07-22-2019 11:28 PM
HOGNIT
Audio Systems
10-12-2016 01:14 PM
Autotec
Audio Systems
25
04-18-2016 10:39 AM
bowhuntenbob
Audio Systems
04-07-2015 05:44 AM
Softail Girl
03-23-2010 09:05 AM
Quick Reply: noise suppressor for audio
