Twin Scan II Arrived Today
Old 10-23-2007, 07:09 PM
NCCopBikeRider's Avatar
NCCopBikeRider
NCCopBikeRider is offline
Default Twin Scan II Arrived Today
Brown Truck knocked on the door at 6:00 PM with package from Dayotna
Loaded Drivers and Software on Laptop
Hooked up USB Cable to Twin Scan II Moduel
Configured USB Port
Confirmed comunications with Twin Scan II Module
Will install on Bike tomorrow night
More to Follow
Thanks for the support
Old 10-25-2007, 02:31 AM
Harleypingman's Avatar
Harleypingman
Harleypingman is offline
Default RE: Twin Scan II Arrived Today
Let the data collection begin.
If you don't have true duals, and when you get a bit more adventurous, fab a sniffer pipe with a slight bend in the tip to go through the right side muffler and up the rear header pipe even a little, and one that is long enough to go past the rear pipe towards the front cylinder. Then plug/cover the left side exhaust. You will get more accurate A/F for the front and rear cylinders using these sniffers in the rightsidethan if you put "normal" length sniffers in the right and left sides.
The left side on the stock exhaust gets a small fraction of the rear cylinder, hence the suggestion to block the left side and have sniffers that can better measure each cylinder seperately.
Old 10-25-2007, 05:44 AM
NCCopBikeRider
Thanks
Currently running FullSac "true Duals" conversion, with what seems to be great success.
Actually running 07 Header pipes with 02 Bungs. Will use those for the WEGO III Bosch 02s.
Bike on Dyno tonight to get "base line".
Data Collection and tuning has begun.
Thanks
Old 10-25-2007, 10:06 AM
Harleypingman
Once you become proficient at using the TSII+, you will become very popular with your friends who will want you todo theirtheir bikes, especially if they have a SERT or PCIII.
Old 10-25-2007, 10:22 AM
NCCopBikeRider
Sounds like an income opportunity
Have a great weekend
cromagnon
08-13-2018 06:45 AM
RG Pilot
03-27-2017 04:30 PM
Kawickrice
Milwaukee Eight (M8)
12-31-2016 11:39 AM
serverpimp
Exhaust System Topics
05-19-2007 07:23 AM
byersmtrco
10-20-2006 07:14 PM
Quick Reply: Twin Scan II Arrived Today
