sert guess im stupid
RE: sert guess im stupid
Angelo,
Try this link and hopefully it will give you a better understanding of the Screamin Eagle Race Tuner and it's capabilities:
http://www.w4jf.com/s_e_r_t_.htm
The cost of a SERT system these days retails in the upper $400 range once you buy the cable set. The module is good for one bike only and cannot be re-used to map the ECM of another bike. It can be used an infinite number of times on your bike, however. So if you want to use a SERT to upload a particular calibration file (EFI map) to your bike, you will be required to purchase the SERT. No other way. Good luck.
QuentiN
12-15-2007 06:07 AM
